AgenticFlow
Q: $749 for 2GB Knowledge storage? I should make a meme out of this.
IMO, the 200,000 monthly credit limitation already makes me feel like I'm buying a weak deal, and despite not inspiring much trust, I can live with it. But the T4 plan being served with only 2GB of knowledge storage... Is this a typo?
Is there any reasonable justification for us to invest this amount of money while only being entitled to 2GB of knowledge storage, which significantly limits the potential of the T4 plan?
ExpertEnoughPLUSMay 23, 2025
SeanP_AgenticFlowAI
SeanP_AgenticFlowAI
May 23, 2025
A: Hi, 2 GB of vector storage isn’t about raw file bytes – it lets you index tens of thousands of text-chunks, which in practice covers thousands of documents (think the equivalent of 1 000–2 000 average-length books’ worth of knowledge). It’s built for knowledge density, not disk weight. Also you can always buy more knowledge storage where needed.
