CutMe Short
Q: 100/500/3000 links per month
As an example 500 links per month, can you explain: is it "you can have only 500 links each month (the same ones, and to create new links, some old links ones will have to be deleted)" or "you can create 500 new links each month"?
JuriyJPLUSAug 25, 2025
Gautam_CutMeShort
Gautam_CutMeShort
Aug 28, 2025
A: Hey Sumo-ling thanks for reaching out.
So you will be able to create 100/500/3000 links every month, every new month you can create respective number of links according to the plans.
Let us know if you need more help. Regards.
