Q: 302 Redirect
Hi Gautam, can I set 302 redirect only for specific URL, while other links will use 301 redirect by default? Thank you.
Gautam_CutMeShort
Edited Mar 7, 2026A: Thanks a lot for this excellent question.
Currently, the redirect type (301 or 302) is set at the workspace level, so it applies to all links by default. At the moment, we don’t have the option to set a 302 redirect for specific individual URLs while keeping others as 301.
That said, we’d really love to understand your use case a bit better. Are you looking to use different redirect types for different scenarios or campaigns? Knowing how you plan to use it would really help us evaluate if this is something we should support in the future.
Hi Gautam, obviously 302 redirect can change the url for the same client. Would you implement this?
Hey, we’ve noted this and will definitely check the feasibility.
As mentioned, currently 301/302 redirects are set at the workspace level, so you can use two separate workspaces to keep your 301 and 302 links split between them. We understand this may not fully address your exact requirement, but we’ll discuss it internally.
That said, it looks like this implementation may not be available soon!!
