Paintit.ai
projects416projects416
projects416PLUS
Jun 29, 2026
Q: 400 credits
Say I want to render 3d interior of one home 2500 sq ft. Then how much credits will be consumed? Any option to have more monthly credits?
Dmytro_Paintit.ai
Dmytro_Paintit.ai
Jun 29, 2026
A: Credits are used per generated image, not by square footage.
So for a 2,500 sq ft home, the total credit usage depends on how many rooms/views you want to generate and how many iterations you make for each one.
We currently have 3 image generation modes:
Basic — 3 credits per image. Best for quick drafts and early ideas.
Balanced — 10 credits per image. Better model accuracy and a good balance of quality/speed.
Advanced — 20 credits per image. The most accurate model, better for detailed instructions and final-quality results.
With 400 credits, you could generate approximately:
133 images in Basic mode
40 images in Balanced mode
20 images in Advanced mode
For a full home project, many users start with Basic or Balanced to explore concepts, then use Advanced for the most important final renders.
Text replies in the chat do not use credits. Credits are only deducted when an image is generated.
For the AppSumo LTD, additional credits are available through one-time add-ons. Higher monthly limits and more advanced usage options are available through regular subscription plans.
