Q: 9:16
Hi are also 9:16 aspect ratio vids supported?
Thank you
torsten6PLUSNov 13, 2024
Marcus_Viewfi
Nov 13, 2024A: Hello there!
Yes, 16:9 aspect ratio is supported.
Posted: Nov 13, 2024
Checking for 9:16 aspect ratio....
Posted: Nov 14, 2024
Yes I know the question was for mobile format vids in 9:16 aspect ratio .thank you
Mobile works in both landscape or portrait. 16:9 does work.
