WP 301 Redirects
luis514luis514
luis514
Apr 14, 2025
Q: 404 report
Hi, I have a question. I really liked the plugin, especially because it detects 404 errors — it’s perfect, I really liked it.
However, the issue I’m having is that I can’t download the data in CSV or Excel format, which would greatly help streamline my workflow.
Ivan_WebFactoryLTD
Ivan_WebFactoryLTD
Apr 15, 2025
A: Hi,
Thanks for using WP 301 Redirects!
Unfortunately, the data cannot be downloaded or exported at the moment. However, you can view your reports within the plugin or the dashboard.
