Q: Does knowledge base refer to the number of domains supported?
I would like to use this for two websites to start (separate companies and URLs).
1) Does knowledge base refer to the number domains I can link?
2) Can I do this on tier one or two?
3) Do the codes stack?
100868829034133947372PLUSNov 16, 2024
Kamal_Kroto
Nov 16, 2024A: 1. Yes it does, although it is a collection of guides to which you can add custom domains
2. This feature starts with Tier 2
3. I am not sure, I don't think they do. You have to upgrade, and the price of the last tier will be cut from the upgrade so you'll have to pay ($TIER2 - @TIER1)
I hope this helps
